Started by BAD APPLE, February 04, 2013, 11:11:59 PM
Time to put her away for the winter, getting to cold to run it now, few plans for winter- pull oil pan and check the crank and bearings, new valve springs, hopefully a 1050 dominator carb and once taxes are done and I get my return I'm going to get a set of boggers
Had big plans for an engine upgrade and a few other things over the winter but looks like I'm going to be in the market for a new daily driver/tow rig now the one i have now might not make it through te winter, so that's not first priority! So te new plan for the bogger is pull the engine replace crank bearings and have the crank ground and then re ring it and stuff it back in, also gotta really good deal on an almost brand new set if 18.4-16.1 tractor tires for it they only have a couple seasons in the field on them hoping work stays busy so I can afford everything
mutt truck
Sounded a lot like my winter plan. But work did not get the memo lol.
I think u will like them tires. Just put two on the rear of mine and man what a difference.
I may cut my two front hawgs this winter but got a lot of repairs for mine that need be done.
Hopefully make it down that way this year a get to wheel with ya.
Quote from: mutt truck on December 08, 2013, 12:36:31 AM
gunna be running my cut hawgs on front too
Got a smoking deal on a set of old style Goodyear 18.4-16.1 tractor tires for the rear of the bad apple
Dano
You gonna cut them or run them as is? Wish I would have kept some of the ones I had.
Gunna keep em the way They are for now they are probably 80% tread might cut them later on would line to find two more for the front also wan aluminum rims for  them
them dont look like boggers?
Cheaper! Boggers will come in time need new Daily driver so had to make sacrifices.
Quote from: BAD APPLE on December 12, 2013, 01:08:51 PM
I just had to mess with ya lol
Quote from: betterbeaters on December 13, 2013, 12:12:15 AM
it's ok lol they are lighter and hook better than boggers do anyway
Recently bought a pair of 18.4-16.1 tractor tires but I need some rims for them so I am looming for some 16x14 aluminum 8 lug wheels, wide 5 is ok to
This should help out a little this year
mutt truck
seeing everyone getting out there boggers for this year really makes me want to get the ole girl ready but unfortunately all of my cash is tied up in other projects, hoping things open up for me so I can get her out and ready soon im starting to have withdrawls again lol
Clinker
I know the feeling.
When in doubt throttle out.
