Started by BAD APPLE, February 04, 2013, 11:11:59 PM
mutt truck
Nothing better than getting rid of the PMS... ( parked mud truck syndrome)  ;D
Quote from: mutt truck on April 29, 2014, 05:24:02 PM
thsts awesome I'm stealing that quote if you don't mind
Well finally sold my old DD so that freed up dome cash to help get the truck going for the year. Pulled it into the garage this weekend. Started tearing the front clip off to make it easier to switch out the valve springs, ordered new valve springs and wheels for my 18.4s. Won't be long now and it will be ready to go
Does the truck being upside down help with valve spring removal also loll
Quote from: michigan maniac on May 14, 2014, 12:38:17 AM
hey man that's how I roll!
After the last bog I took the truck to last year I changed the oil and found a metallic substance in the the oil, out if fear of it being bearings I decided to park it for the year, I finally got to look into te issue and discovered that at high rpm te cam started walking and the timing chain gear on the cam was rubbing the block. so I took the gear into work and milled out a pocket for a thrust washer to sit to eliminate this problem. So we should be all good to go once I get the valve spring in and my wheels made up for my 18.4s
4-play
mine did the same thing a few years back...same fix...now i have a belt drive
Welded the centers in my wheels, painted them up and got the tires mounted on them yestersay
Tires on wheels
Going farming lol
Quote from: betterbeaters on May 27, 2014, 12:38:47 AM
Going farming lol
yessir going to be tilling up some black muck!
Lol better get to it
Needs a good cleaning and she's ready to roll
Took the ole girl to Amish country for a small Time comp bog, won the open class in some thick nasty clay
Here is the link to the full open class
Clinker
It looks really thick. Nice work on the run  applaudd   ==kv
When in doubt throttle out.
Its kinda like wet concrete, doesn't help tht my shifter won't let me down shift and that the motor is gettin pretty wore out
Rumor Has it!
Bowtie Or Die..
All tucked away for the winter months pulling motor soon getting ready to upgrade
