Started by BAD APPLE, February 04, 2013, 11:11:59 PM
Looks like I'm picking up a roll cage for it friday
Got the 4 link bars all done just need to get spring mounts done, and new mounts for the hydraulic steering ram made up and the 60 install will be all done and I can move on to the body swap, also picked up a nhra certified roll cage for it
355REDNECK
were did you get your 4 link bars at
WHEN IN DOUBT THROTTLE OUT
1 1/2 inch square tubing 1/4 wall bought a 10ft stick at n.e.f.co.in Hillsdale
355REDNECK
were did you get your heim joints at
T.S.C top links. You can buy the high dollar hiems if you want but these are cheap and they hold up really well
yukonjake
solid 12
Looking good!  Hope to see it run this year!
Quote from: solid 12 on April 06, 2013, 12:15:00 AM
yeah me too lol I need to make some time to get it done, I c yours is coming around nicely! Your dad still have his truck?
Have a bid on a se of coil overs for the front right now nothing special they aren't long travel but they will work for me jut hoping I win them so it can stand on its own. If I don't win them then I will start on the coil spring perches and get my old shocks mounted then on to the body swap
solid 12
Quote from: erikmud on April 06, 2013, 12:58:07 AM
Now that I'm on day shift it is a lot easier to get work done, still a lot to do but if I keep at it won't be long.  Yup just gotta do a few things then his will be ready
Boggen Joe
Quote from: Boggen Joe on April 07, 2013, 04:57:43 PM
It's going to be sweeeeeet. I see
i hope so, just waitin on an auction on eBay to be over on a set of coil overs hopefully I win them once I have them it will be setting on its own then off comes the old body and preparation for the new tin begins
Unfortunately I lost my bidding battle for a set of coil overs so have to settle for running coil springs hopefully have it sittin on its own weight this weekend
Newbie
Hell yeah! Looking good! Just swing over anytime I wanna 4link mine :)
Picked up some more protective goodies couple new sets if g force 4 point harnesses
Got alot done today finished the 4 link mounted springs attached the steering cylinder and mounted the shocks got the tires back on and Its finally setting on its own weight, now time for the body swap
mboies
Those ground hawgs always been grooved? If so must have just never payed attention.
Quote from: mboies on April 13, 2013, 09:20:24 PM
ran them half of last year they work good still have to scoop the lugs
