just got one 10 mins ago
Started by GET-R-DONE, March 01, 2013, 10:41:50 PM
GET-R-DONE
I just got this one 30 mins ago traxxas motor runs when I hook the battery straight to it but won't  run when I put it and use the controller any help or make an offer
RUN YOUR TRUCK NOT YOUR MOUTH
more  info will help like what truck is it, does the steering work, give as much info as you can and we'll try to help but with what you said it could be a few things.
GET-R-DONE
It's a traxxas stamped steering does work I'll get some pics up soon
GET-R-DONE
drogers
gmc all the way
GET-R-DONE
Here's a pic
GET-R-DONE
I changed the esc nothing changed
drogers
do you have the ecu pluged in the right spot on the rx
gmc all the way
GET-R-DONE
Quote from: drogers on March 04, 2013, 07:04:02 PM
i think i tryed all just in case so idk whats wrong
Is it a 2.4gzh radio or is it an AM/FM with crystals?  If its a 2.4 you may need try to rebind it.
Could also be in LIPO mode and no t in NiMH/NiCD.  I am guessing it still using the Traxxas ESC.
But yea if you have a NiMH/NiCD battery and the ESC is on LiPO battery mode it will not turn the motor b.c the low voltage cut see the fluctuation of the bttry and thinks its dieing so it will not move the car.
Hope on Traxxas website to find out or go to a local hobby shop,
Also that is not a Stamped its a Rustler.  Stampeds have different chassis and dose not flare out at all
GET-R-DONE
Quote from: Cannaert link=topic=82176.msg851822#msg851822 dati know its a rustler i monted that body one=1362432379
Merc09
GOOD BATTERIES IN THE CONTROLER? LOL
GET-R-DONE
Quote from: Merc09 on March 05, 2013, 06:38:19 PM
put brand new ons in but it dont steer or move
so it dont steer or move?  is it a 2.4 system or what?
GET-R-DONE
Quote from: betterbeaters on March 05, 2013, 07:13:21 PM
idk off hand I'll look and I have a stamped frame if any body's interest idk how much to ask
GET-R-DONE
Kay I put the battery in push the esc botton it turns green for like 5 seconds then shuts off the I hold the button agine it trans red
muddslut
It may need to b reprogramed or the esc and recever is bad
