q-jet
Started by uncletuck, March 12, 2013, 07:28:57 PM
uncletuck
i have a few quadra jets carbs laying around i how do i tell what size they are i got a bbc i want to put one on
I think they are all 750 cfm.
uncletuck
o man that would be sweet thanks
73chevytruck
I think there an on demand carb they use what they need upto 800cfm. There good carbs if rebuilt/working right.
uncletuck
im going to rebuild one and throw it on...it beats whats on there now
Run the numbers, or post em there on the side of the carb body, they are on demand carbs, use as much fuel that's needed, SBC q-jets are around a 650-700cfm max and BBC is around 800-850 cfm max, either or will work on a BBC unless your running s monster loll
frist thing to do is how bad are the shaft are in base plate. that is the biggest problem with them.  sucking air though the shafts.
uncletuck
Thanks guys i have 9 to choose from and its for a 402 bbc so 750 should be plenty
Red97
look  down the primarys, if there is a slight bump in one or both of the primarys than it is a bigger carb. if  no bump then it is a small carb.
hot rod heep
If none of yours are any good I have a pile of them to if u need any parts it peases
03 jeep liberty  on k5 frame
Dana 60/14  410 gears
44 boggers
BBC th400/208
Merc09
Quote from: uncletuck on March 13, 2013, 01:33:16 AM
Would ya wanna let one go for cheap? Lol
uncletuck
Yea i can do that
