Going carb
Started by larry60, March 20, 2013, 11:48:22 PM
larry60
Getting rid of fuel injection and going carb already got the carb and intake just need fuel regulator and dist the guy i got the intake from told me to go with 1 from proform 1 wire thats it
Boggen Joe
larry60
89 302 roller motor out of mustang getting rid of all the computer junk dont want to run right told going carb would fix that
fordrunner
Some one did a carb swap on my truck and I'm in the process of fixing it lot of things thay over looked. Fuel presher is the big one! What's your motor doing could be simple
larry60
No power when you put it gear sounds good not in gear
fordrunner
#5
What firing order you running how's the fuel presher. What's it in the roller h.o morors run the big block firing order
larry60
went gear to gear on timing checked both ways on timing checked compresson at first it ran good i could spin the 44s on pavement now not had bigger injectors went back to stock went with mustang computer that didnt change anything talked to alot of differnt people most said i changed too much stuff for it to work right no smog or h2 senors and some vacumes but i have no leaks anywhere
larry60
still working on it gotta go with fuel cell and inline pump burned out stock pump but when it did run sounds alot better
larry60
well i blew that motor up at tgw in hale gonna go with a holley 600 on the next motor was told that 750 was too big burned too much
gas had nothing to do with blowing up motor i can get a good deal on a rebuilt 289 thinking of going that way everything is set up for carb now
