where can i buy battery cable by the foot?
Started by redneck renegade, March 21, 2013, 11:29:18 PM
redneck renegade
carquest no.autozone no.tsc sells 50' rolls but than i'll have 35' i dont need. any help would be appreciated.
Quality auto in fmuth that's wherever I got mine.
redneck renegade
Right across the street from mike youngs just north of subway same side of the street. It's not gonna be cheap for 15-20 ft.
redneck renegade
Quote from: Crazymays77 on March 21, 2013, 11:34:35 PM
its 50 for a 50 foot roll at tsc hope its cheaper than that
redneck renegade
stillcheaper then a batt. relocation kit i guess
It's 49.99 for 25 ft of red and 59.99 for 25 ft of black at tsc online. It's not gonna be much cheaper than that anywhere. But if u don't need that much get it buy the ft carquest in Millington should have it too.
redneck renegade
Quote from: Crazymays77 on March 21, 2013, 11:46:44 PM
What u trying to do.
i put my batteries behind the cab.just trying to run a + to the solenoid and i wanna put a couple grounds motor from frame.
Places that install plows usually just pull all the wiring when they do upgrades, might be able to get it cheap that way.  I did.
HellYeah4x4
 I ran 2 batteries in the back and in my case 4g wouldn't supply enough amps. Burned up 1 starter trying to get er to fire the first night. I had to upgrade to 2g wire and had no problems. I use 2g to supply the starter and 4 g for my engine and chassis grounds.
grainger   and do you have an air gas store or  a welding supply shop   dont use standard battery power lines waste of time and $$
fordrunner
I used welder lead cable in the bronco I might have some left have to look
72 Bogger
If you can find a place that does wheelchair lifts for handicap vans they will have it also. Or
Find one at a scrap yard
drive like you stole it
redneck renegade
thanks guys looks like i got some options now
lilred
Use a heavy gauge jumper cable!! Cut the ends off
As others said... welding cable.  Nice and flexible and not too expensive.
