Spider gears and carrier
Started by WHITE KNIGHT, May 02, 2013, 11:43:02 AM
WHITE KNIGHT
Looking for spider gears and carrier Dana 60 front thanks 8109381201
I Got Mud!
WHITE KNIGHT
410 gear  even a rear 60 will work was told spiders are same even with a different gear?
I Got Mud!
WHITE KNIGHT
Trying to get ready for opening day mounds if not I'm going to weld it like rear just need room to turn lol
I Got Mud!
carrier are the same and gears are the same standerd cut. spider gears for rear end are 30 spline and front spider gears are 35 spline.  what do you real need??
WHITE KNIGHT
Front spider gears 410 ratio someone had a roll pin holding in pin , broke one small gear when it broke still can use my carrier treads our gone for pin bolt , weld bolt in if have to ?
I Got Mud!
roll pin is right!! its dana not a gm axle....
WHITE KNIGHT
Still need the spiders for carrier , wow I thought it was wrong with a roll pin instead of a bolt and your right I'm use to gm ,well going to call on new set today and find out , what is right or wrong , I looked on line and it showed 30 or 35 for front?
I Got Mud!
'the DON'
#8
im sure you got 30 spline out 35 in. Just count them on the axle
==wgm
your d60 front with have 30 spline outers and 35 spline inners you need front spiders. its easyer to get new I looked for 2 months to find spider gears used.
WHITE KNIGHT
#10
Count spines when I get out of work .really just need one small gear and shim behind it cash in hand ? Got pulled apart last knight getting close to mounds opening , but this year going to be wheeling jeep a lot more much less money for sure  thanks guys
I Got Mud!
blittle913
I might have something...let me know when you find out exactly what your looking for.
When in doubt, throttle out!
i have tons of little ones those are the same in all open case's  i did see today i have one front case 35 spline
BC775
I have the spiders and carrier out of a GM Dana 60, had a 4:56 gear tho not sure if there the same or not
WHITE KNIGHT
#14
Ok did count 35 spine inner but I really just need one small gear and shim behind it I can use other 3 gears cross pin got little chipped on end but could use if not one around ,willing to pay for part , if u can help it would be great 810 938 1201  thanks cliff
I Got Mud!
WHITE KNIGHT
I Got Mud!
WHITE KNIGHT
4x4xdodgeman  u said all little gears are same? Fixing to scrap a 1/2 ton Chevy 93 can I pull spiders out of that rear 10 bolt corp and take little gears out  are they same or ? Or would u be willing to sell me one or to that u have?
I Got Mud!
4x4fun
Call DTS down here in Warren, i know they can ship right to you... they are the Dana dealer down here i deal with, pretty good guys..
GotMud?
when yes said all the same i mean dana 60 are all the same.
