Piston looks melted.
Started by 73chevytruck, August 29, 2013, 01:25:40 AM
73chevytruck
Friend has a .60 396. Bought a few years ago. Finally getting around to do something with it. I pulled the heads off and one of the pistons looks like its been melted. Would it be ok to still run it. Or should it be replaced?.
need to put it out and look at it. if melt down the side into ring land then its junk.  wrong octane gas or timming
fordrunner
Its a failer point waiting to happen I'd swap it out while its torn down just my 2 cents
X2 swap it out, and yea wrong octane, bad timing or running carb to lean is the cause
Quote from: xjs3667 on August 29, 2013, 07:07:19 AM
or too much nitrous
Thumper
replace it, it's just a bomb waiting to happen
THE D&D CREW
73chevytruck
Yea its going to be replaced.
Quote from: marshall on August 29, 2013, 10:08:58 AM
or too much nitrous
:-)  forgot about the nitrous loll. It will do it in a hurry
73chevytruck
From what I understand somehow the heads had the wrong size valves in them but still let it run.
Wrong size valves wouldn't melt a piston...
Yes that's true what you have there is detonation cause by wrong timing or to low octane fuel or a combination of both
