fuel in jected 460
Started by Captn. J, September 09, 2013, 12:45:08 AM
i m thinking about putting a  FI 460 in my truck  will it mate with the c-6 i already have ?   motor mounts? anything else i gotta worry about?  my truck s a 81
fordrunner
Use you're old motor mounts every thing else is the same if you use the surp set up its fairly easy
eyeless goat bogger
C6 will mount up.  You plan on staying with fuel injection. You cant put a carb on a fuel injected engine. Heads are different.  But the ford 460 block never changed casting
