solutions to throwing belts
Started by hollywoodhillbilly, October 02, 2013, 02:54:04 AM
Boggen Joe
I use to went to Dayco belts, and short as I could. I haven't thrown a belt in over a year, and I spin 7000 rpm
Wicked Willys Fab
#21
I ran a acc. pulley on the backside of the belt to keep tension on it never threw it after that
Wicked Willys Fab
hollywoodhillbilly
Whered u find that small pulley at
Wicked Willys Fab
Auto parts store can't remember the part number but seems like it was for a ford ranger I'll look around and see if I can find the box I know I have it - you will have to cut a spacer or use some washers to line it up
hollywoodhillbilly
And you just bolt it to the head?
Wicked Willys Fab
#26
Couldn't find the box for it - the factory alternator lower bracket has a hole in it that's what I used
night train 2
mine kept throwing the power steering belt so i found a larger pulley and cut the outer portions of it off and welded them to the outer edge of my existing pulley which made the pulley about an inch deep, couldn't throw the belt if i wanted to now.
