solutions to throwing belts
Started by hollywoodhillbilly, October 02, 2013, 02:54:04 AM
hollywoodhillbilly
Anyone have some solutions to an engine throwing belts at higher rpms
73chevytruck
My truck use to throw belts all the time. I switched to tractor belts from tsc and it hasn't done it scince
Quote from: marshall on October 02, 2013, 03:53:36 AM
install a serpentine system
x3 I had good luck with dayco belts but still had them come off
hollywoodhillbilly
What should i swipe the pulleys from
Merc09
Quote from: hollywoodhillbilly on October 02, 2013, 01:51:10 PM
What kinda motor? If its a 350 you can pull the accesory bracket off of a tbi motor and a tbi water pump and a tbi crank pully.
hollywoodhillbilly
Quote from: hollywoodhillbilly on October 02, 2013, 05:44:44 PM
What about a 454. Same thing
if you have a big block you will need the system off a big block, if you have a small block you need the system off a small block or a 4.3
get some belts with no notches on them. on the bottom or the v part of the belt. what is happening is the notches grab the pulley and walk up the pulley at high rpm and come off.
RaZiN KaNe
#11
Quote from: betterbeaters on October 02, 2013, 11:00:01 AM
the shorter and tighter they are the better they stay mine don't  come off anymore it just flips over like a good woman  ++peace ==np ==wgm
B.G. Grounds Maintenance
NuttinButtMudd
Quote from: RaZiN KaNe on October 03, 2013, 06:42:37 PM
Love it!
It truely is a Jeep Thing ,   you wouldn't understand!
https://www.facebook.com/JeepsofMichigan
  "Mamas Other Toy"         "Angeleyes"         "Back In Black"
https://www.facebook.com/groups/472065446191384/
Merc09
Remember if you go serp belt you need a new water pump the v belt style pump is different.
Swampthing
Let me guess,you keep tossing the alt. belt.  The pulleys aren't lined up correctly.  It works fine for every day driving, but get it over 5500 rpm's and they come off.   The easiest fix is finding a serp set up off a 86-87 bbc.  the flat belt only ran the alt and water pump.  it still uses the standard water pump.   You can buy a aftermarket set of pulleys that actually line up.
if he wants that set up I have one.    swampthing
Did he ever say what this is going on?
hollywoodhillbilly
hollywoodhillbilly
My fathers pulling truck has a real bad problem throwing belts. Stay on fine getting it off the trailer and lining up to the sled but the moment he puts the coals to it it throws them and i was needing cure to fix his and solutions to mine so they wont fling them. Would hate to throw a belt miles back in the woods
