86 Chevy 2.5 ton SOLD!!! shes heading north.
Started by 4WHEELMAN, October 31, 2013, 11:31:44 PM
4WHEELMAN
86 chevy, 2.5 ton rockwells welded rear open front, 4-link, 1.25 Heims, 14" FOA coilovers, Built 383 stroker, Chevy race bowtie block .40 over, 4 bolt, 1 piece seal, all forged internals- crank, arms, pistons. Hydraulic Roller cam, Ceramic coated Hooker headers, high volume oil pump, Dart Pro 1 Platinum aluminum heads 202's, Comp Cams 1.6 Magnum Roller Rocker Arms, Comp Cams Pro Magnum Hydraulic Roller Lifters, Comp Cams gear to gear timing, Comp Cams 2-piece timing cover, Hurricane highrise intake, Quickfuel 1050 carb, duel fuel filters, inline high pressure fuel pump, fuel regulator w/pressure gauge, MSD ignition, Distributor, Blaster coil, RPM rev controller, and wires, fresh Turbo 400 w/ stage 3 shift kit, manual valve body and 3000 stall, Derale trany cooler w/ fan,Cyclone trans case, 24x10 custom powder coated wheels with 14.9x24 BKT 171's, dual radiators both with dual fans (flex-a-lite fans),Mezeire electric water pump, March serp. set up,B&M truck shifter, DIY brake kit on rear axle. On-off switch cluster for electric water pump, radiator fans, and tranny cooler fan. Gauges include-RPM, water temp.,oil pressure, volts, and tranny fluid temp, Hydraulic steering, 14 gallon aluminum fuel cell, dual batteries w/on-off master switch.
Location Ocala, FL
Asking 22k obo
Or trade for 2010 or newer Polaris Ranger or RZR of equal value or with cash.
Art
352-274-4917
EvilWays
very nice truck!!!!good luck on the sale looks like a very nice piece!!!
When the throttle hits the bull p00 quit's!!!!!!!!!
yukonjake
4WHEELMAN
bigblue81
4WHEELMAN
Well ladies and gentlemen she is heading north with her new owner.
Merc09
4WHEELMAN
I dont know if hes on here but truck is headed to Ohio
