88-98 gm trucks.
Started by hollywoodhillbilly, November 10, 2013, 03:42:58 AM
hollywoodhillbilly
Could you do a sas on these and put an old style drive train and axles in these and have everything work right. Id like to put a gm dana 60 and 14 bolt front and rear axles a 454 bbc a th400 trans and a 205 transfer case in one
yes that can be done...............its just that the cheapest route is using a ford front axle to maintain your current driver side drop t-case and trans.
cheapest route is to use every thing he has listed. no buying any axles or tcase. chevynut did not read your post all the way and thank of what you said.  all your stuff will work just fine! put it together and have fun!!!!!!!!!!
hollywoodhillbilly
Y go hunt down a ford axle when i have all my listed parts above sitting in my garage. Built ready to be installed. So i dont have to look for any driveline parts
solid 12
Yup,  everything will work just fine.  Put 60 front, 14 rear, 406-400/208 in it.  I eliminated lots of wires under the hood too.  Everything works great!
hollywoodhillbilly
Will the stock steering bolt up or do i have to get the crossover kit
Quote from: 4x4xdodgeman on November 10, 2013, 02:28:06 PM
I read the post clearly................his original post didn't mention anything about  already "having" those parts...........and I assumed that he didn't.
If your donor truck..... (88-98 truck) already has EFI...........do you plan on swapping that out for a carb'ed motor??
Quote from: hollywoodhillbilly on November 13, 2013, 02:13:09 AM
Gonna have to go crossover. Steerong boxes are on different sides of the framerail
Merc09
Quote from: Kyle on November 13, 2013, 06:06:51 AM
Youd be better with crossover steering anyway itll handle way better.
hollywoodhillbilly
Its got a boat anchor tbi 350 and its getting a carbed 454
Just needs bb motor mounts. Altho u may have to make or modify to get the trans and tcase mounts
