should I
Started by Boggen Joe, November 27, 2013, 12:56:56 PM
Boggen Joe
Should I stay with my 1 tons 4:88s with 44s
Or should I go to 2.5 rocks with 48-52 V treads
Just throwing ideas around. I don't have any problems becides trans but the FTI will fix that
Will be harder to fit in your garage with Rockwells... Guess you'll have to raise the garage and put a hoist in ???
one thing is how many   other things would ya have too change too put the bigger axles in ???
just one more
if it aint broke dont fix it, you will never keep up with the jonse's lol
rocks i would say since you can get them for 1k  from  me    one tons re probably same priced or a lil more     thats just me      run what u want
My main concern with rocks is how do the Gus get good wheel speed out of them with such low gearing? And what is the weight difference between a complete Dana 60 and a complete Rockwell
84silverado
#6
Quote from: BAD APPLE on November 27, 2013, 04:00:32 PM
when my 2.5 rocks (1 front and 1 rear) came in on the frieght truck the slip said 1900 lbs flat, but thats with everything on them still from the M35A2 they came out of. but even when i de-braked them i prolly only lost 200-250 lbs-ish, but then i added my pinion brakes and lockers so i didnt lose much cause the lockers wiegh 9 lbs on there own and the pinion brake prolly wieghs 7-8 lbs complete? in all honesty the only place i can think of that i lost weight is switching from a cast iron NP205 t-case to a SCS t-case loll
If you want to be light and fast/ wheel speed stay with the one tons, if you want to be slower with tractor tires go with the rocks, unless you plan on 4 linking the whole thing and building a nice big block to gain some wheel speed back,
Its personal preference Joe....  Im glad I did it.. If you do it, 4 link it and be done... biggest regret I have is goin leaf spring... and I know that is a big argument amongst people too.. leafs or 4 link..
If your happy with 44's, that's all that matters..
My truck is no more.. tore down, new build starting, all 4 link, new motor, big cubic inch..
I ran 1 year with rocks and 44's and I year with V treads,   I wouldn't go back for nothing.. love the v treads..
The mega truck thing is getting huge and only getting bigger....wildtime is building an off road park for mega trucks which will be awesome too
littleripper
Just fix the trans AND RUN THE dog crap out of it
BUGET BOGGER'$ CLUB   89 BRONCO
1 tons and 44s vtreads are for tractors and belong in the fields draging plows
Quote from: betterbeaters on November 28, 2013, 03:01:21 PM
what about 1 tons and tractor tires?
Quote from: BAD APPLE on November 28, 2013, 03:43:13 PM
Too much carnage !!  Joe If I were you I would stay one tons and get a nice set of boggers, then cut the rear and leave the front uncut
nope tractor tires go on tractors. lol just not a fan I like boggers :)
Quote from: michigan maniac on November 28, 2013, 04:29:05 PM
18.4-16.1 tractor tires aren't that hard in 1 tons they even weight less then a 44 bogger
Boggen Joe
Quote from: BAD APPLE on November 29, 2013, 12:14:28 AM
huh
redneckmafia01
Lol keep the 1 tons. Once you start breaking your 1 tons. Then upgrade. My opinion.
RaZiN KaNe
Quote from: betterbeaters on November 28, 2013, 04:37:30 PM
I LIKE TO RIP THEM HOLES WIDE OPEN AND IN THE SWAMP V TREADS AINT GONNA GET YA WHERE A BOGGER WILL TRACOTRS ARE ONLY GOOD ON TRACTORS!! IF I WANTED TO DIG TO THE BOTTOM ID BRING MY JOHN DEERE DOWN TO THE HOLE.. ITS ALL ABOUT WHEELSPEED TO WEIGHT RATIO AND STAYING ON TOP OF THE SLOP! WHEN IN DOUBT THROTTLE THAT MOTHERFU#$ER OUT JOE!
B.G. Grounds Maintenance
Quote from: RaZiN KaNe on December 03, 2013, 02:32:22 AM
:) yep
Quote from: betterbeaters on December 03, 2013, 12:07:47 PM
:) yep
whens the last time yall ran it in  D  high gear   1to1 on the trans???   im runnin 53 inch Michelins  rim and tire weigh as much as 2 boggers and a d 60       last time  I was stuck the front bumper was under the dirt yall was there  all depends what on  makes ya happy
