Roll cage etc
Started by Mudduck, December 27, 2013, 04:13:46 AM
Mudduck
I m doing researching on roll cage and looking for few info.  Hydraulic tube bender or manual ?  12 ton tubing press good enuf?  Tubing notcher on e bay goes from 60 dollar n up.  is the 60 dollar one do-able?  For those who have done roll cage or exo cage in the past, would u do it yourself or have someone do it for ya?
Mudduck
==hstrap
Merc09
I've used a manual one, it will get you by, but if you plan on making a lot of bends or multiple cages ect... The hydraulic is nice to have,  as far as tubing notchers the cheap ones don't last long,  most notches can easily be made by cutting the tube on an angle with a chop saw, to make it resemble a fish mouth, once you get the hang of it its pretty easy, and a small grinder makes it easy to adjust the notch if needed
