Body work?
Started by camok10, February 09, 2014, 05:49:35 AM
camok10
How hard is it to weld in new cab corners? I have never done body work. It's a 98 Chevy ext cab with out the third door. I'm sure my rockers could use some love too but they seem solid enough to clean up and bed liner.
84 c10 project
82 c10 beater diesel
Mudduck
Not hard u gotta spot weld it so the metal don't over heat n start to melt
Mudduck
==hstrap
Don't spot weld going one direction around the perimeter. Your going to want to do opposite end spot welds to keep it from warping. Think of it like tightening a lug nut, cross pattern.
Mudduck
Quote from: Jthomas on February 09, 2014, 02:41:16 PM
correct
Mudduck
==hstrap
duel1985
Don't rush it either or you will have more time in the end when your ready to paint . This is when slow and steady will pay off...
newS10
Can you weld? As this is a must on this job. ==hmmm
camok10
Yes I can weld, arc, mig and am working on tig on my free time at work.  I have a basic understanding of keep it cool to prevent warping, alternate spot welds from end to end with time between I'm just curious at to if there's any tricks. It dosent have to be perfect it's getting covered in Bedliner once done.
84 c10 project
screw the patch in place and weld the holes as you pull out the screws ;D
camok10
Quote from: BigFrank on February 10, 2014, 10:09:46 PM
That thought crossed my mind!
I also found some automotive body adhesive, if I got a crimp tool I could glue it in place, has any one done this method?
84 c10 project
that glue is some tuff stuff  i  never used it on a exterior body panel but ive used it on a couple floor boards worked good
newS10
Quote from: camok10 on February 11, 2014, 05:53:16 AM
The adhesive/glue works good. 3M makes a good one for this, it is a 2 part but you will need a gun 4 it.Good luck welding or doing the glue as they both work well.I just like the welding better.
camok10
New s10, it sounds like you've done a bit of body work?
84 c10 project
redneckmafia01
Weld it. Keep it cool. Even if you have to let the whole panel cool down. It will save a lot of time later. When your metal finishing the welds, keep it cool.  When I've made the panel to hot I've taken a wet rag and pulled the panel back to were it was a couple times. If you take your time you shouldn't have to do that.
