any 6.5 specialists guru or goofballs on here ???
Started by BigFrank, February 12, 2014, 12:52:30 PM
fordrunner
The 94 I had to drive for a land scape company was jumpy to I hated that truck. Ended up getting it hot pulling a trailer and burned her up. So he bought a 93 motor and that was a mechanical pump so we had to put the 94 eletrice pump on it. Never did get the jumping out of it.
camok10
84 c10 project
82 c10 beater diesel
pmd was relocated when I got it  ive tried  2 other pmds with no change   what does the resistor doo ???
Adds more fuel for more power, and I've heard if you stay out of the throttle better mph
freerev
you need a pump for a 94 to 2000. sounds like thats your problem. i had the same issue with 2 of my 6.5s new pump and pdm with a relocation kit and a #2 resistor fixed both of them. i did my 2000 at 98000 it now has 345000 with no problems
Quote from: michigan maniac on March 24, 2014, 10:42:12 PM
where doo ya put this resister
camok10
On the Pmd over two pins were the wiring from the pump goes
84 c10 project
Quote from: camok10 on March 25, 2014, 07:30:14 AM
Yup, basically just slide it in the pmd connector, and connect the wiring back up good to go, it can take a few times starting for it to take effect also
