dana 60 question
Started by tmspike, February 12, 2014, 07:50:38 PM
tmspike
Is a dana 60 front axle out of a one ton dually any different then a dana 60 front axle out of a standard one ton  .  I know the rear axles have different hubs but what about front axles.? Talking about Chevy axles
Merc09
#1
I would think it should be the same.
Same axles, different hubs.
tmspike
Whats different about the hubs? Different widths??? Is a front axle off dually wider?
Quote from: tmspike on February 12, 2014, 09:14:48 PM
yes i believe so   u can have them machined down
mutt truck
Yes they are slightly different, I have one, they are an external bolt on hub and are increasingly harder to find. The rotors are also different as the offset is grater than a standard. Other than that I believe them to be the some.
hubs are I wanna say 6" wider per side but it makes using a 15" rim alot easyer
Hub is not wider.. mounting flange for the wheels is..
dually hub has the lug nut flange out near the lock in.. where a single hub has the lug nuts in by the rotor..
you can convert a dually hub by cutting/grinding the wheel flange off..  remove the rotor mounting bolts and get longer ones.. reassemble and mount your wheels in near the rotor..this will move your tire/wheels in about 4 - 6" and put you back to a single wheel track for each side.. if you mount tire/wheel to a dually type with say a Corp. 14 rear your front tires will sit wider than your rear tires and create 2 wheel tracks per side.. which in certain circumstances can be an advantage and in other circumstances not so much.
85cHeavyMetalBogger
I know my d60 front is a lot wider then the rear d60 I run
tmspike
