any nitro experts? i need your help!
Started by CUCVonROCKS, February 27, 2014, 12:14:16 PM
CUCVonROCKS
So I have a Traxxas T-Maxx newer model 3.3 truck. I ended up destroying the connecting rod in the 3.3 a few weeks ago. So I bought a lightly usedofna force .28 to put in it just to get it moving faster. I bought all the stuff I need to put it in the tmaxx and when I began the install I realized that the stick out on the crank shaft is too long, it puts the clutch bell past the little flywheel and into the side of the transmission. So I wanted to know if they make replacement crank shafts that are different sizes? ??? And if not, is there any bolt in big blocks for the tmaxx? Any help would be appreciated ==wgm
fordrunner
We never did find a bolt in big block. We did 1 on a buddys and redilled  the mount holes. But it never did work right. If you just want more speed go down on you spere gear teeth a couple teeth. The 3.3 rod is hit and miss if you get a good 1 there OK but I split 2 in my old truck. If the piston and sleeve are OK a rod is like 30
I used to have a Tmaxx that I converted to BB and I know the engine I used (don't remember Many many years ago)there were a few different style crank snouts.
CALL HARTLAND R/C HOBBY SHOP.  810-632-0106
Ask for Donovan on some help for doing the swap and what you might need. (I work there with him just about everyday). I am off tomorrow but he can help you out. Knows way more then I do about about Nitro motors.
