E85
Started by jbeery78, March 05, 2014, 11:41:38 AM
jbeery78
Anyone running E 85 in there boggers? What does a guy need to do to switch? I know ethanol can be corrosive to fuel systems, wondered what I had to do to my carb etc to make the switch. Seems like cheap race gas to me...  ;D
Boggen Joe
I know you can send your carb out n have it done for like 300-400
Andy Michalik
I've got a e85 750 on my Chevrolet drag car runs great tip cheap race has now I can run it more
its just like running alcohol, use twice as much as gas. it draws moisture so you need the test tube to see if it has water in it.
camok10
To switch your going to need an ethanol compatible fuel system, lines pump seals ect. You need to run the engine ritcher with it either by re jeting or getting an e85 carb. To tune it in your going to want about10:1- 9:1 afr as compaired to the 14.7:1  with gas.
84 c10 project
82 c10 beater diesel
jbeery78
Yup I know how ethanol draws moisture, I plan on reworking my fuel system to be compatable with it. Do you guys think a 600 cfm edelbrock is enough carb to run e85 thru or should I step up the cfm? Motor is a 400 ford have a healthy cam heads smoothed up aluminum intake dual plane and headers.
AtvNut
Use a 750 for that many cubes
AtvNut
You don't need an alcohol fuel pump I haven't had a problem using a regular Holley blue pump
AtvNut
If you plan on using pump e85 buy a can of e98 to mix it up to true e85 you will need a tester obtainable from your Briggs and Stratton dealer
Looks like 300 to get it converted using your edelbrock http://www.e85carbs.com/EdelbrockE85carbs.htm
I would run at lest 850cfm to 1000cfm carb
mud slinger
We ran e85 on are bogger we had no problem....u will need a bigger fuel pump aslong with a e85 carb kit....we ran quick fuel carb...but if u call them up they will set u right up
Andy Michalik
Mine is also a quick fuel 750. Edelbroc will set it up for you I think there is a air bleed you have to solder shut. Bigger from isn't always better if you slow down air speed you can loose power I would stay in that 650 to 750 from range
From the link I posted they prefer 500-600 cfm edelbrock carbs for the conversion, but once converted it can never be switched back... So I'm assuming they open it up for more fuel and change the cfm rating regardless of what you start with
jbeery78
Ok sounds like I need to get in touch with e85carbs then. From what I find online theyre the go to guys on it.
Andy Michalik
They guy who started the Edelbroc conversions I spoke with on the phone a year ago he seals up a few Ports not needed then drills a few bigger then puts you're good rubbers. Neoprene in them and rejets
