Basement block builds pics of the 383 up
Started by HalensDaddy, March 27, 2014, 09:15:04 PM
HalensDaddy
Building a 1963 sbc .60 over 283 I'm rebuilding the factory power pack heads porting and polishing them myself and installing new valves and springs in the lower end I'm using a factory 283 steel crank with 5.7 h beam rods with the .60 over flat tops and installing a mother thumper cam with a offenhouser dual plane intake no fuel pump roller tip rockers and some nice push rods hoping to get some good rpms out of it for my chevette and I'm gonna bolt it to a 2 speed power glide.
Picked up a sbc 355 that comes with a scat 383 stroker crank 6.0 rods 600 lift cam aluminum 205 160 valves aluminum Brodix heads edelbrock single plane intake 750cfm demon carb all roller motor with all msd ignition with Billit distributor and a nice race pan that I'm gonna carry into the basement and tinker with.
And then there's my 406 stroker that is all in boxes still with the price stickers that I need to get my hands into but probably won't happen until my Malibu is ready for it lol
great white buffalo
HalensDaddy
No its going it into a chevette two door lol
great white buffalo
Mudgrunt
Back in the day Chevette's with v-8's rocked, I think it's cool you are building one.
Life is not a dress rehearsal
HalensDaddy
I got my 383 parts today did I get a good deal for only payin $1500?
great white buffalo
HalensDaddy
205 valves brodix aluminum heads ported and polished
great white buffalo
HalensDaddy
Goodies
great white buffalo
HalensDaddy
6.0 rods with arp bolts all brand new
great white buffalo
HalensDaddy
Pistons 12:1 compression with ristpins locks and rings
great white buffalo
HalensDaddy
600 lift crower roller cam
great white buffalo
HalensDaddy
Brand new scat steel 383 crank
great white buffalo
HalensDaddy
Roller rockers idk what kind tho I forgot
great white buffalo
HalensDaddy
Roller lifters forgot what kind
great white buffalo
HalensDaddy
More lifters and rockers and valve covers and push rods
great white buffalo
HalensDaddy
Demon 750 carb
great white buffalo
HalensDaddy
Double timing chain
great white buffalo
HalensDaddy
Edelbrock single plane intake
great white buffalo
HalensDaddy
Timing chain cover
great white buffalo
HalensDaddy
Oil pan
great white buffalo
HalensDaddy
And the block with a GM steel crank 5.7 rods and flat top pistons brand new freeze plugs bored 30 over I just need to figure out if it spun a rod bearing or a crank bearing so I can get my machine work done and have my bottom and put in
great white buffalo
