cummins engines
Started by BigFrank, April 02, 2014, 10:18:16 PM
was out looking around at the honey hole  and theres a cummins engine sitting there pretty much complete   I don't know much about them as far as what would have too be changed too put it in a 3/4 or 1 ton pickup /mud truck    first thing  I seen was the power steering pump mounts are about 10 inches higher than the top of valve cover  and the oil pan has a big sump in the front   but the  biggest question too me is what would I have to be changed too hook it too a gm trans  its got a stick flywheel on it
frdzila
Need a gm bell housing for it they did make them most were found on 4cyl Cummins but they will fit a 6bt
Quote from: frdzila on April 03, 2014, 12:02:56 PM
cooll I looked at it again today  theres a ford  sticker on the side of it  they took it out of a cube truck that got flipped on its side  only thing  I can see know is the oil pan
84blazer
One thing about the cummins engines that is nice is just about everything is interchangeable. They are all basically the same block with different parts bolted on for different applications.
Quote from: marshall on April 03, 2014, 10:04:05 PM
6.5 delete kit, lol
nope  got something else on the back burner just gathering parts for it
