Chevy ZZ350
Started by Catmando, May 09, 2014, 07:10:44 PM
Catmando
Well the purple junk is back together and it still dose the same thing. Had the heads milled and checked for cracks and all is good there. Still pushing to much coolant out the over flow. Any ideas anyone
More backround?? Radiator plugged? What water pump you using? Forward or reverse rotation ?  Does it boil over with the radiator cap off?  I would use block checker and see if the is combustion gasses entering the coolant,
Catmando
Radiator good. Not sure how to tell what waterpump I have
Get one of these !! Can save you a headache
My guess would be a cracked cylinder too
