fuel cell setup help!!
Started by Tonyw15, June 12, 2014, 12:56:07 AM
Tonyw15
switching to a fuel cell in the bed of my truck, looking to see what setup would work with my truck. running a chevy 383 stroker and want a 22 gallon fuel cell. i just dont know what pump or sending unit to run. please help so i can order parts. thanks!!!
Tonyw15
cant, removing my fuel tank to fit ladder bars.
What kinda truck? What kinda fuel cell? Is it carb or fuel injected, need more info? Pure off road or race truck ? Do you really need a sending unit to tell how much fuel you have ?
Holley pump and regulator would be my suggestion
Tonyw15
82 chevy, 383 stroker with Holley 750DP carb. Looking into a Summit 22 gal plastic cell.  going to be used as a dune truck mostly and to putt around town/ cruise around.  Sending unit would be  nice if it was accurate
I would say what ever the tank manufacture suggest then as far as fuel sender, everything else could be hit or miss
For fuel sender....measure the ohms on stock one with float down then again with float up.....and then you can get one for your cell that's within those specs and u can use your factory guage
I am running a mechanical pump right now with my cell.
your truck should use a 90 ohm fuel sender for the guage. As for the pump if you want electric just throw a holley blue on it make sure to use a filter before pump or pre pump and post pump.
