95 GMC C1500. $2500 or trade
Started by Cannaert, June 21, 2014, 01:56:40 PM
I have my 95 GMC C1500 up for sale. Has 350/4L60E in it, Truck has 98,XXX miles and it Runs and Drive great truck had 82k on it when I picked it up 5 years ago. It has a lot of new parts installed on it in the past 2-4 years.
Has been swapped over to 6 lug with LD C2500 Front Rotors and SF 14 Bolt rear end (3.73 Gears were stock and were installed in the axle)
New parts or work done to it.
All under hood sensors -Summer 12-
Fuel Filter -Jun 13-
Fuel Tank and Sending unit. -Jun 13-
Fuel Lines -Jun 13-
Front Rubber Brake lines -Aug 13
Rotors and Pads -Aug 13-
Shoes and Drums -Aug 13-
Brand new Ring and Pinon -Aug 13-
Exhaust Y-Pipe back -Sept 14-
Headers -Sep 14-
Head gaskets done when doing headers (broken manifold bolt so I pulled the head took it in to a shop to have it drilled out) -Oct 14-
New U-joints and Center support bearing -May 13-
Has had any and all rusted body panels replaced on it - Since 2012 to Now
I have brand new Rocker Panels for it as well that have Never been installed-
New Oil Pan installed -Aug 14-
New Ring and Pinion to match OEM 10 bolt gears 3.73 -Aug 13-
New Valve Cover gaskets -Aug 14-
New Accel Cap and Rotor -Aug 14-
New Performance 8MM Accel wires -Aug 14-
New Plugs ACDelco plugs -Oct 14-
New Edlebrock Air Cleaner housing with Spectrum Washable filter (also have the Factory Air Filter cover with a Spectrum filter to go with if wanted) -Jun 14-
New Smoked out Headlights, Turn signals and Side markers -Apr 14-
New Roll Pan installed and Weld to the Bed -Feb 14-
Brand new Battery -Oct 15-
Hamburger TBI Spacer -Sept 14-
Rebuilt exhaust from Y-pipe back -Sep 15-
AC Delete installed -Sep 14-
Will have A Set of 15" 80's Rally Rims with Center Caps install on it when it sell
Fiberglass topper in great shape just needs Lift struts, Has brand new Lock and and Handle on it. A.R.E. Topper
What it needs done.
Painted all one Color
Could us an alignment, Pulls a little bit to the Passenger side (Trying to get this taken care of as well)
Has a leaking brake line in the rear. I have yet to find out where it is leaking but the master cylinder in empty
Only other thing it need finish up is the Heater core hoses need new fittings install. The Quick Disconnects no longer will stay in the fittings. (I have new ones just need to install them)
The Black 17s can go with the Truck for an extra $350
The Silver 17s can go with it the Truck for an extra $150
I have way to much money invested in this truck and Will never get back. Was going to be a project for my son and I but he want to build the old S-10 I have.
Will trade for anything that is 4WD, Legal For the Road and Not Junk.
Needs to be something that is DD and Safe for Kids to be in.
Bump.
Working on the Headers and Y-pip right now.
Also Added in a 15" E-Fan to it.
Just replace the starter as well as it was under warranty
I also picked up some new tires for the 17's
Great Project for someone.  Lots of Goodies for it.
Like to sell it soon, Picked up a a gas saving car and this needs to go. To many vehicles sitting here and I could use the money to pay off some bills.
theitguy
Lowering kit for what? Isnt this truck 4x4?
theitguy
C1500 means 2 wheel drive? I didnt know that good info what would mean 4x4? Was going off photo with the z71 on the bed but yes anyone can put a bed on a truck.
Thanks for explaining that Marshall.  :thumbsup
Bump.
Truck Fired right up Saturday for me. Then Monday I went to move it and all it does is Crank, Fuel is spraying in the TB but no spark now.  Need  gone. Truck is worth more then I am asking for sure.
Dropping the Price to $2200 with out all the extras
Need it gone. I have to many things around this place and each one is driving up a wall trying to find the money and time to get them all donw.
Bump. Need to sell this soon.
Bump truck runs like a top now, just needs a brake line fixed.
