got a tire question
Started by MudDigger, July 07, 2014, 02:47:10 PM
MudDigger
ok guys so i bought a pair of 26x12.00x15 mickey thompson sportsman S/R the question is will they be ok to mount on an 8inch wide rim without wearing out the center of the tire? i read you can have a tire 4inch's wider then your rim is this correct? thanks in advance
MudDigger
night train 2
Quote from: MudDigger on July 07, 2014, 02:47:10 PM
a radial will ride flat but if you spin them the center will grow in size and will wear sooner, a bias tire will bulge in the center so you will have to adjust the air pressure and again if you spin them the center will bulge.
dose the tire say on the side of what they want it mount on?  some do say it
