Ring and pinion setup
Started by OHEARN.2012, August 01, 2014, 09:51:05 PM
Possibly looking for someone that could help me set up a ring and pinion in a 78 ford hp dana 44. It came with I believe 3.73 gears and im stepping up to 4.10s can I use my same carrier and spider gears or will I need a new one? I Can provide the parts and money for the job. just looking for someone who can show me the steps involved in setting them up. I have no experience doing this. If someone pretty close would be willing to help me out that would me awesome. Thanks Kyle.
mudbillyredneck
Utube has videos ;D
Or powerblock tv
Same spiders are fine, but install new bearings and get the shim kit.  Pm me or big Todd for a quote on us installing for you.
you need different Carrie. the split is 3;73 down / 4;10 up
Quote from: 4x4xdodgeman on August 06, 2014, 04:58:44 PM
turns out he's right.  Hp has a carrier break between 3.73-4.10, that means the shim stacks change on the carrier too, a little bit bigger job.
jbeery78
If you need so help or have a few questions just pm me.... I'd come give you a hand if I wasn't so busy and far away.
