Question .....
Started by Boggerb, September 24, 2014, 11:19:03 PM
Boggerb
I have a set of axles from a 3/4 ton dodge non floater rear 60 , 44 front. Will 15" rims fit on my axles?
Boggerb
Looking to buy rims and tires and if I knew for sure that 15s would fit it would make it a lot easier!
have any friends near you, that you can borrow a wheel from to test fit? that way you'd know for sure.  ==2cents
I have one here you could try, I'm in mayville.
I've never heard of anyone having any issues with a 44 front, only on a 60 front because the brakes are bigger, I personally have 15's on my Dana 44 right now
Rumor Has it!
Migt have to grind the caliper a lil but should def work
Bowtie Or Die..
Boggerb
night train 2
Quote from: Boggerb on September 24, 2014, 11:19:03 PM
if their drum brakes it shouldnt be a problem but with disc brakes you might have to grind the caliper down about a quarter of an inch, it all depends on the back set of the rim.
Boggerb
Drums in back disk in front
Boggerb
Got a rim from a friend the disc front fit but the drums were too big !
