motor plate ?
Started by Boggen Joe, December 23, 2014, 02:34:40 AM
Boggen Joe
Will like a sprint car motor plate work for mud truck? I want to plate mine n seen these. Idk if strong enough for what we do
Probably need a mid plate and front plate
mudbillyredneck
Quote from: marshall on December 23, 2014, 03:17:58 AM
Yup yup, and matching converter spacer.
night train 2
Quote from: Boggen Joe on December 23, 2014, 02:34:40 AM
i made my own front and mid plates out of 3/16 steel
, if you run a mid plate make sure you use converter spacers at crank and bolts.
Boggen Joe
Quote from: night train 2 on December 24, 2014, 03:26:07 PM
so space the flex plate out_?
night train 2
no Joe, put spacers between the flex plate and converter same size as the mid plate, i weighed mine to keep it balanced, make sure you get the same size spacer for the nose on the converter to the crank.
Boggen Joe
