deisel fuels ???
Started by BigFrank, January 24, 2015, 01:41:33 PM
ok   soo for a couple months now  I have been  buying diesel at the same place  just because  its local and close too home   the other day I had too go into baycity and was getting  low  like  less than 1/8 of tank   soo  pulled up too the pump at speedway left truck run since my wife was with me  started  pumping  fuel into it  and actually watched my truck start smoking out the exhaust  thought  wtf is going on here   went around town and did what  I had too and it never stopped and seems too have gotten worse   any body have this happen too them before  ???
Quote from: Mudbuster on January 25, 2015, 10:36:42 PM
Quote from: Captn. J on January 24, 2015, 06:35:35 PM
Injectors?
x2
I was told  they were all changed 20k miles ago  cant hardly belive they would  just go bad or stick open all at once  in past experience  I have   they usually get  loud and make a lot of noise when there getting bad or stuck
gojohnnygo
I always start with fuel filters and some 911 n see what happens from there.
Quote from: BigFrank on January 26, 2015, 01:40:07 PM
Injectors?
x2
depends on the quality of the injectors and it only takes one to cause the smoke. do you have any type of programmer on it, or a scanner that can read the balance rates?
I have a scanner but idk if it would work to check the injectors on a diesel.
Quote from: Mudbuster on January 26, 2015, 05:04:12 PM
Injectors?
x2
no programmer or nothing on it   probably take cory up on the scanner and atleast check it for codes  I was told a mass air flow  sensor going bad would make the computer dump more fuel  than is needed    it just weird that as im putting fuel in it  it started smoking  I mean whats the chances that a injector would fail at the same time  or  did it stir up crap in the tank   I don't know run it till something fails I guess
I knew when I got this truck I should have just fixed my suburban   lol   ==sick ==sick ==sick ==sick ==sick
Swampthing
Different gas stations put additives in the fuel for the winter time. One of the worst stations I have found for this has been BP. Run the tank down and put fuel in it from the station that you normally use. You may have to do this a couple of times to get it all out,but it should work.
  I actually switched to speedway deisel for the winter time. I am getting better mileage and it starts easier in cold weather.
mudbillyredneck
Quote from: Swampthing on January 27, 2015, 03:34:15 PM
X2 with my own personal experience as well
3 tanks  now and the smoke has all  stopped     ;D
