how do I get this off??
Started by welder.up99, March 15, 2015, 04:47:59 PM
welder.up99
My 82 crew cab has developed a shake recently coming outta neutral into first.  So upon my inspection it seemed that the drive shaft joint that mounts to the bottom of the frame is bad. I assumed that the drive shafts would split there but they dont. How do you get this mother flipper off?! ==pissed
Argon Addicts Anonymous
NuttinButtMudd
unscrew the cap on the slip joint and the shaft will slide out
It truely is a Jeep Thing ,   you wouldn't understand!
https://www.facebook.com/JeepsofMichigan
  "Mamas Other Toy"         "Angeleyes"         "Back In Black"
https://www.facebook.com/groups/472065446191384/
72 Bogger
Quote from: NuttinButtMudd on March 15, 2015, 07:26:54 PM
Then you will have to have the carrier bearing pressed off and the new one pressed back on
drive like you stole it
Hammer and chisel it off, just be alot more gentle going on with new one and use a flat punch instead of sharp chisel- works, done a bunch of them  ;D
