1989 TBI 350 $650, drive it home.
Started by lilred, March 16, 2015, 04:40:33 AM
lilred
1989 TBI 350, $650 *drive it home*
comes with 2wd 3/4 ton chevy truck, 4 speed manual (sm465?) (L, 1,2,3) 212k on ODO.
Less than 6k on clutch, new clutch master cylinder &  slave cylinder, newer hitch, newer water pump. Probably needs a clutch fork, everything was working fine then it just stopped. Slave cylinder pushes the fork all the way back to the bell housing, clutch still isn't releasing. I'm done working on it. It will drive but I wouldn't go too far, I move it around the yard starting it in gear.
Call or text 989 873 7619 located in Otisville MI
Did you get that Suburban put together yet??
eicks383
lilred
mainly needs to be driven. Other than that the blower fan goes on HI speed as soon as you put the fuse in. I have a ignition switch with keys that goes with the truck, right now uses a screwdriver. I think thats about it that I can remember.
lilred
bumpp again, new info added, tired of working on it, probably something as simple as the clutch fork. Drive your new bogger motor home. $650 ==wgm
ourlittleranger92
Will to trade for short block 454 that just needs crank turned?
Chevy Race Car Ford Mud Truck
Chevy Daily Driver
