motor swap HELP!!
Started by BLZNBIG, April 14, 2015, 03:29:34 PM
BLZNBIG
Putting a 94 350 tbi in a jeep Cherokee. Wondering how to go about hooking everything up to keep it tbi. Any sugjections would help. I have the whole truck. Jeep has carbed 350 in it now
Pull engine harness and ecm, throw in an aftermarket fuel pump 13-14 psi, and you should be set. Keep the check engine light and obd port  wires intact, and reuse. That way you can check the trouble codes and diagnose issues if you have them
4x4fun
Quote from: J.C. on April 14, 2015, 04:55:36 PM
Hes correct.  use the entire harness with pcm.  I put a 94 tbi 454 and 4L80e in my 86 1 ton tow rig, works beautifully!
BLZNBIG
Would I have to run the gauges in order to do this or just the light.?
BLZNBIG
Also run the fuse box from the truck also?
dirtydog
they sell a wiring harness with a lot less sensors and crap to run tbi. I got one I use to run t.b.i engines on my run stand. simple n easy has obd port no fuse box n just basic sensors that r needed to run it.
BLZNBIG
Do you remember where u got the harness?
1 ton tj
off road the way of life
dirtydog
From another member on here when I bought my vortec motor iutta his crawler.  Affordable I believe is brand.
4x4fun
On mine we printed up wiring diagrams and built it off of that using what was needed to run the TBI computer and kept the existing 86 gages.  As far as speedo, that's a hole nother story..
GotMud?
I use a GPS for a speedo when there is not one in the truck that works, usually pretty accurate  ;D
