HELP WITH A HOLLEY
Started by lil_umpa316, May 26, 2015, 11:32:41 PM
lil_umpa316
looking for some help tuning my jeep i have 4 barrel intake on a 258 straight 6  with a holley 600 /vacuum secondaries  runs good just seem like its dumping fuel bogs out  when u get on it need some one to come tune it
FREAKZILLA III
BlueChevy07
lil_umpa316
no just got to run it lean man
FREAKZILLA III
BlueChevy07
You can only run a carb so lean before you hurt it even worse. Just did a job putting carb on same motor. It took around a 400 to get it tuned right.
lil_umpa316
do u know witch way  the screws turn for more and less air/fuel
FREAKZILLA III
Turn the screws in for less fuel.
I'm running a 470 cfm on a 4.3 v6 and it's too much at times. So you running a 4 barrel 600 is too much. I had one on mine but I disabled the secondaries so it worked ok.
lil_umpa316
alright thanks how would u u go about disabling the secoundaries
FREAKZILLA III
BIGBLOCKXJ
if it bogs when you open the throttle, you have to much air and not enough fuel.  That is why there are accelerator pumps on the primary side of the carb.  Try to change the springs that open the secondary's up to slow them down.
lil_umpa316
alright well im going to just wing it for at millinton and then figure it out then
FREAKZILLA III
you just need to tune the carb in, its not to big.  a friend ran a 3310 (750 cfm) on one the with small cam in it.
lil_umpa316
thats what im saying it runs good just getting to much fuel i got a header on there which  makes her scream
FREAKZILLA III
