please delete
Started by jimmy02, October 31, 2015, 01:36:57 PM
jimmy02
Delete
Thats a lot of work to do to put in realativly weak axles. What are your plans for it?
Its a decent deal. As long as you dont V8 it and keep it in the 35 inch tire range you'll be fine. As for springs, longer will ride and flex better.  Fab up some brackets so you can use lift springs ftom a WRANGLER?
looks like a wide track 30..
Ive had difficulty finding R side inner shafts..
mine is V8 on 36" swampers and 5:13's locked.. CJ 4" lift springs.. gotta stay outta the go pedal when turning.. but goin straight!!!!   ==djdj   holds up depending on pedal application and ground I'm on..   definitely off the pedal when landing....
learning curve was expensive.
