Never E-Nuff update 3-2-2025
Started by Gearz, January 02, 2012, 06:41:43 PM
Gearz
Gearz
Well its been to long I know. Still sitting on stands. Started hyd steering an just going to put new 4:56 gear in front no funds for changing to 5:38 . Had to stick a boat load of cash in too hauler front end all rebuilt ready to haul now.
Quote from: Gearz on June 24, 2013, 02:53:31 PM
yup time to de mothball the ole girl,
Quote from: Orangecrush on June 26, 2013, 04:21:17 AM
I got the hookup for making hyd  lines  let me know  if ya need some
Gearz
Quote from: BigFrank on July 06, 2013, 11:31:52 PM
[/quote]        Just had hoses made today and then seen this . Thanks ! for the offer
Gearz
2013 TGW Hale  Back to the drawing board bent both new rear leaf spring for second time.blown out both rear shocks springs resting on body mounts. Thinking its time big shocks and a cage almost rolled it over. Had it up on 2 wheels left foot got heavy.
 This truck tore up Hale, I do believe he probably went through the most gas, everytime I looked it was out rippin the place up, even on two wheels,
==wgm a=f ++peace
Quote from: Orangecrush on September 01, 2013, 12:35:50 PM
==wgm a=f ++peace
Hell yes!  He even got gas from me too after mine broke!  lol       ==dj
Gearz
 ++peace installed heavy duty rear shakle flip. Grinding pearches off to fix drive shaft angle. ready to slide back under truck and weld new pearchs on. have to fix wiring going to starter an change starter. wires all fryed going to it. Got hot by headers
git r done!!!!    rockwells next
Gearz
TGW 2014 ran strong no problems new style high torque starter work great. ++peace
rob69
Looked good out in the pit! You gave her a good beat down!
Gearz
Nothing new sitting in the snow waiting for spring still have bent springs in rear a should address
Gearz
#95
Wow been a long time sence last up date. 2015 truck ran great. MMJ was fun filled week. Truck needs new rear springs for this year. Truck pulling was a blast at mmj 2015. Truck was flawless!!!
Gearz
#96
Time too catch up on updates.
(2016) Truck got  bran new rear leaf springs, Big shock bump stops in rear ,Rear water tank sprayer for windshield.
MMJ 2016 Ran the p00 out of it till i started hitting a big jump harder an harder. Till i cracked the transmission and bent the new rear leaf springs. Riding on new Big shock bump stops now and Bleeding transmission fluid
(2017) sat on jack stands in corner.
(2018) still sitting on jack stands.
(2019) 7-29-19new transmission an transfercase back in. Trying too make MMJ 2019 have too hook every thing back up an then try an fix rear leaf spring problem.
Gearz
2019 did nothing too springs still riding on bump stops.  Made MMJ did tugs at hard hat bar. Hooked too my brothers Denali Duramax. Bed loaded with asphalt. Transmission was not working right. Lost bad. Loaded up headed back too MMJ Pulled transmission.  Pulled a second transmission  apart for parts. Rebuilt put it back in. Ran all over mud pit transmission worked great. Did find out problem with rear springs got a 58" should be a 54" spring. Explains why they keep bending. Order a new set an should solve this problem.  From the beging of this build.
Gearz
Wow long time since update. Ran truck few mud party weekends and a friend's Batchelor party night. That night was it's last run for a while hit a tree head on and it did not move. Lol
Which started the give it some love stage. Put on stands in back corner garage. Fixed all new front end an bumpers. Started - all new plugs ,wires, msd distributor, all new fuel filter system,radiator,belts,new timing tab,high torq starter,all fluids changed. Getting close hope to get back out there this summer.
