what do you guys think about driveshaft loops????
Started by BLZNBIG, December 29, 2007, 08:29:58 PM
BLZNBIG
i was wondering what you guys thought of driveshaft loops??? because i was wondering if they helped out alot incase of breakage??? what do u guys think ? ? ?
Kodiak450r
i know on performance cars they are a must have. if you run a front and rear loop it'll save the underside of your vehicle in case of breakage. a spinning driveshaft will whip around wildly at any speed and cause some major wreckage. you can see for yourself if you have a universal joint for like a socket extension. put it in a drill or air gun and give it a go. it'll whip around quite violently causing damage.
MILKTOST
I wish I had loops when I broke the yoke on the rear axle.
1998  Wrangler rollin on hacked up Hawgs
Squirell
Econo-box from Hell
Driveshaft loops are a great idea. I need to get off my butt and install some on my rig.
==nw geoo ==wn
i have them on the  front of  mine,   i broke  the  side of  my trany  out  from my  drive shaft   swinging around.   soon to be on back.    safty is allways  good.
definately very good to had! blew up my front shaft at a bog, flung around and bent up my oil pan a little bit. it finally found itself a home between my spring hanger and the frame loll coulndt get that ==cuss outta there!
Driveshaft loops are a GREAT thing to have when they break.
look up some videos on you tube.. when they go... they go out with a bang!
mike
if your just muddin trail riding they are great. but if you ever plan on hittin the rocks they can be a hinderance as far as clearance goes. they are deffinatly a good investment if its not a rock crawler.
2000 durango r/t, stock
Fun online 4x4 role playing game http://4x4country.net/register.php?ref=6565
millser
i hit oil pan to just to lasse to put them on but thanks for a reminder im going to do that this winter
SteveP612
I had them on the Jeep that I use to own but Im going to install them on the new truck this winter.  They are a great safety device.
1997 Jeep Cherokee and 91 YJ
bogger564
i dont have any but they sound like a good idea !!
==rf   chevvv    ==rocks
Required for some events depending on your setup and event sponser
Laws of physics (and Murphy) can be a bytch
bigdawg41
i was at the local transmision shop today. they just had a 95 bronco come with a broken front driveshaft. for some yet unknown reason the front driveshaft locked up at about 60 miles per hour and gave  the driver  a new experience driving terror. the front shaft was in at least 4 pieces that i saw. after the bronco was up on the hoist the damage was more visable. shifting cable broke , transmision case broke, transfer case broke, front output yoke broke, 5 holes in floorboard from broken driveshaft spining out of contrtol, PRICELESS!!  i  was planning on putting loops on anyway , but now i  plan on putting 2 on each axle.
Bo Duke
Quote from: bigdawg41 on January 19, 2008, 04:12:35 AM
Yup im getting them...
Squirell
you can get them out of summit or jegs for like 40 bucks
mudboggincrazy
x2
Quote from: Econo-box from Hell on December 30, 2007, 03:08:27 PM
bigdawg41
last weekend at Thompsons I saw three trucks that could have used  em!
blasterguy911
yea they are a great idea makes it a pane in the but when you have to change the driveshaft but it will save you an oil pan
1972 bronco
ive seen people make them out of 5in well pipe and drill hole in the webbin of the carrier and mount them that way....that is what im going to do very soon!
