Kill Switches
Started by Ranger Dave, June 02, 2009, 12:39:10 PM
How many of us in here have  Kill Switches in our  rigs ?
just wondering.  im glad i had one in my rig !  donnie  was able to shut mine down.  i was  under the hood.
big thanks  donnie
Bo Duke
I need to put one in my rig....
Be nice to have for safety reasons and for when i store it i wont have to disconnect the bat...
yep got 1 toggle and one master disconnect!
Donnie and I were talking sunday about this. We think we all should have one and everyone should know where they are in each rig. so if something happens we/anyone can kill the rig fast. I have one in my tracker put not in the jeep. I do have a toggle that shuts the gas off in the jeep but its not instant takes a few seconds to shut down.
yup..ignition and electric fuel pump         shut off with one big red button!
Quote from: Bowtie972 on June 02, 2009, 04:35:26 PM
Same here. One big red button.
key'd main power..
ignition kill
fuel pump kill
I like to use a seperate button to shut everything off, because if you turm the key off, at least in my truck the column still locks, so youll lose your steering too.
mudboggincrazy
my hole trucks run on toggles  flip it off and the truck dyes now no need for one on the fuel pump its mechanical also have my fire extingusher right at my left foot on the rocker  easy for any one to get at as long as door is open
solid 12
i've got a master kill switch first then power switches for everything else after the main power
hot rod heep
my hole trucks run on toggles  flip it off and the truck dyes now no need for one on the fuel pump its mechanical also have my fire extingusher in between the seats
03 jeep liberty  on k5 frame
Dana 60/14  410 gears
44 boggers
BBC th400/208
Quote from: Big Blocked CJ 5. on June 02, 2009, 04:38:34 PM
same here one BIG RED button
ballistics-10
i have switches for ignition, fuel pump and my fans. I have 2 main battery disconnects that kills everything at the same time. i have one in the truck and one on the outside of the truck just incase something happens to me someone on the outside can shut the truck down.
littleripper
i don't have one yet but i do want one i think it is a good ideal all off road vehicel sould have one
BUGET BOGGER'$ CLUB   89 BRONCO
Mudduck
Mudduck
==hstrap
mudslayer2008
where do you guys put them ???  I want it out side the truck excessable but out of the way of mud and water.
NOTHING ON THE PICK UP STILL USE THE KEY         ITS A TURN KEY BOGGER         THE JEEP WILL HAVE THEM
My Jeep has a Toggle switch for the Fuel pump and ingnion on. Key is there to start it.
But one I get my 700R4 in it I will run the furl pump on its owe switch and the Ingnion on its own as well.
just one more
toggle fuel pump, keyed ignition.
Bultema4x4
Ive got a Flaming River cut-off switch in the inner passenger side fender that goes to the starter and my ignition switch.  On my shifter Ive got a toggle to my electric fan and the distributor.  The key in the ignition is still needed because it runs my turn signals, windshield wipers and unlocks my steering wheel. Ive got 5 seperate toggles for 8 aux lights.
1987 Mazda B2600. 350 crate, 700R4, NP208, 35 inch Swampers.  Seating for 4. . <br ><br> Run your TRUCK, not your Mouth.
