86 Bruzer Project-Update 4-29-12
Started by CBakes, November 06, 2009, 10:13:28 PM
cnoswalt78
it would be nice to have the 52'' front springs but make the rear shackles able to move to multiple spots forward (for a spring swap later on) and your factory length springs will work for now. then set everything up like a 52'' swap (itll be moved 1 or 2 inches forward and with the drop crossmember itll be higher.
Shoot man with the lift u have now u should clear 44s no prob, may hanta trim a tiny bit, I only run a six inch lift on mine and I clear 39.5s. No problem, and could jump up to a 42 easy and maybe 44s.
CBakes
Quote from: Blazin40s on December 14, 2010, 01:31:07 AM
I hear ya, I know I can make the 44's fit, just want good clearance so I don't rip a fender  off or dice a tire. I am moving toward 1 tons but would really like to 4 link it.
I like to keep the center of gravity as low as possable, I don't wanna roll, lol. I really think I could squeeze 44s under mine with some more trimming
CBakes
Quote from: Blazin40s on December 14, 2010, 02:09:05 AM
Thing about mine is that I have the bush wacker extend-a-fender on it and would have to take those off to trim...a lot more work to it.
Yeah those flares look good.  I was gonna get some too, but my tires don't stick out enough.  But they look bad ass on yours
CBakes
Quote from: Blazin40s on December 14, 2010, 02:20:16 AM
Thanks, I like them too....The tires that I should have on wednesday will fill up the wheel wells pretty good....44x18.5x15 gumbo's. They'll prolly stick out past the flares!
Wow gumbos huh???  So did the ground hawg deal get fixed?????  Was that one not repairable?
Brad & Mookie
P.M me when u need 1 tons. Im puttin rocks on the K-5 this winter. There all set up for 4-link. All brackets and tabs,hydro-steer,1410 yokes,456 gears there bad ass. save you lots of fab time..
Brad & Mookie
chevvv     CHEVY FOR LIFE     chevvv
"91" shorty /w 468 BB,5 speed/"91" k-5,d60'4-link,16"travel coilovers,44 cut hawgs
CBakes
Quote from: Blazin40s on December 14, 2010, 04:07:49 AM
The deal is all good and was taken care of well. Yup, gumbo's and we'll see how they do!
Glad u didn't get screwed put up a pic with those gumbos when there on
CBakes
Quote from: Blazin40s on December 16, 2010, 12:15:47 PM
gonna try to get them on at some point today. Been sitting on jackstands for too long.
trailman
my 44 gumbos work awsome for me
CBakes
Quote from: trailman on December 17, 2010, 03:18:47 AM
i'm excited to try them for sure!
Blue
If your gonna go that big i would suggest switching from a 700r4 to a 350 turbo. i noticed a big diff. truck is looking Good man
CBakes
Quote from: 79 Money Pit on December 17, 2010, 03:47:53 PM
the 700r4 is a monster performance trans. Built for up to 600hp and if I get to a point where I need to upgrade, i'd think about going a diff direction. Right now the trans has less than 2000 miles on it in total.
CBakes
