Redneck Ranger NEW MOTOR
Started by redneck renegade, February 18, 2010, 04:52:44 PM
redneck renegade
so far i've got a 2"lift in the back mustang rear coils in the front that give it about 4".ripped out the 4.0 5spd and gave it a 351 with a edelbrock intake holley 600 carb and dec uprights.it has 3.73 gears which should work fine with the 351 torq since the truck weighs under 3500lbs.its got a c6 and borg warner manual t case behind the 351.it rides on brand new 36x12.50 super swamper tsl's
mudboggincrazy
its gonna be sweet get it done u wil luv the v8 power in that little truck
trailman
redneck renegade
your going to like that sbf  in that.  if you  need help  don't be a fraid to ask.
redneck renegade
everything has been mocked up.engine mounts were easy to make.the v6 crossmember worked.little lost on making the alternator work the only part i kept of the original harness was the ign. wires and fuse block so i know i can start it just not sure how to keep it charged?!
get a  GM one wire alt  for it. that what i run.
drill the  hole out to fit your  bolt,   one wire to batery  your  done.
Quote from: Ranger Dave on February 18, 2010, 09:27:43 PM
dave knos that engine runs
redneck renegade
Quote from: Ranger Dave on February 18, 2010, 10:13:25 PM
thats the route i'm gonna go thanks
MidMichiganMudRun
Sweet... we will see in the spring how it goes
redneck renegade
Quote from: puddlejumper on February 19, 2010, 12:42:05 AM
should go alright if the front end holds up
mudboggincrazy
Quote from: eric payea on February 19, 2010, 03:06:14 AM
i see sas in the future then
redneck renegade
Quote from: mudboggincrazy on February 19, 2010, 03:28:59 AM
yea if i coulda found a dana 44 with 373s i woulda done it already but matching gears are over the budget right now
Got a set od chevy half tons w 373 gears for $150
