project RECOVERY ONE
well picked up the new heads today! found me some dart iron eagles! 2.02/1.60 valves, camp cams roller tip rockers and .500 lift springs! all for $500  yeahh the guy said they had less than 10 hours worth of run time on them since they were redone
Hitman89x
Nice find =) im trying to locate alum. 302 heads =P
Quote from: Hitman89x on February 27, 2011, 02:04:44 AM
movin on to chevy motors now huh? ==roll *hint* chevy 302...
Hitman89x
NO WAY! ford 302 =) goin for 350 HP
Quote from: Hitman89x on February 27, 2011, 06:23:11 AM
thatl give it a lil more pep! hope the drivetrain keeps it all on the ground!
You might ought to run them heads through the machine shop and have the valves and seats checked/ground. I can see in the pics that the exhaust valves are different colors, indicates possibly something going on there..  ;D
Quote from: old school truck dude on February 27, 2011, 04:38:04 PM
different colors? these were run very few hours... could that be just cuz theres very little carbon on em? the heads were literally bein pulled off the motor when i got there to pick them up
Im concerned over the ones that have black exhaust valves. Kind of wonder why.. Also wonder why they only ran them a few hours? When you have 8 cylinders, all 8 should show uniform color, but when you have a few showin darker, it means there might be a little somethin somethin goin on there.. I like the tan ones, looks good. Opinions can differ on just exactly what "re-done" means. Could be nothin to do with the head, but definitely worth lookin into before motor is assembled just to be on the safe side.. Murphy's law.. It does sort of look like the fuel mix was good for the middle cylinders and not so good for the cylinders on the ends. Still a real good deal, great find! JMO  ;D
7d9_z28
he didnt run them long cause the bottom end took a p00. cant remember what exactly it was...
pistons all looked good when the heads came off too
camok10
Quote from: old school truck dude on February 27, 2011, 08:40:02 PM
possibly single plane intake it would get a good mix to the middle 4 but not so much to the outer 4?
84 c10 project
82 c10 beater diesel
Quote from: 7d9_z28 on February 27, 2011, 10:24:06 PM
rod started knockin cuz the HV oil pump sucked the pan dry
on the far left cylinder i had used my finger and rubbed some of the carbon off. the middle 2 were basically untouched and the far right one im pretty sure it had some coolant on it and it looks like some of the carbon was falling off too. i do kinda see what ur talking about tho... and to be clear i had REALLY poor lighting when i took the pictures
Hitman89x
Quote from: Kyle on February 27, 2011, 11:17:37 PM
I like to have all my stuff i buy checked out anyway even if it looks good.. pulled heads off my 2.9 looked good didnt see any cracks till took them in and the found one massive crack... always good to be sure =) only cost afew bucks at that..
Yup, I pretty much question everything especially when it gets up in the hundreds of dollars  ;D
Quote from: old school truck dude on February 28, 2011, 02:12:32 PM
hey thats not a problem with me! i appreciate ya pointin that out to me! i do appreciate any input on anything, im still learnin what all to look for
Quote from: 84Chevy on July 27, 2010, 05:48:55 PM
My question is how come you didnt upgrade to atleast 3/4??? I plan to SAS my 99 some day when money allows.I already have a 8 lug front, still need the rear and a pass. drop tcase to bolt to my 4l60e.
they make a pass side drop tcase for a 4l60e?? i have one in my 94 and gettin a pass side drop would make getting a axle easier
do you have any upclose pics of leaf spring top plates and upper shock mounts?
Quote from: OHEARN.2012 on March 02, 2011, 04:01:53 AM
passenger drop 241 should bolt right up to it
Quote from: OHEARN.2012 on March 02, 2011, 04:09:34 AM
theres pics on here for the top plates, aint gonna get much better for those. as for upper shock mounts, which parts are u more concerned about?
Disturbed Sledneck
well got the front driveshaft back from D&R Driveline yesterday. got it all clearenced at the pinion yoke and flange again so its all good to go!
