Make it Solid (update)
Started by AFurg85Chevy, April 03, 2011, 02:18:10 PM
AFurg85Chevy
Figured i would share with all of you what im trying to accomplish on my own in my shop, never done body work, never torn the body off a truck, but im learning, Cab mounts, truck bed braces, everything is that basically holds the body onto the truck is rotted out, this is what ive got done so far, I tore the box off an replaced 4 of the 5 cross braces on the bottom of the bed
AFurg85Chevy
I used to work at Sherman Auto parts in Washington twp, And they have everything for that truck even dash panels, so i get my parts through there, fairly priced to on some stuff
94chevy_4x4
looks like ya did a good job  ++peace
roodawakening
AFurg85Chevy
#6
Heres an update on the truck, I have both wheel wells cut out and replace along with the patch for the back of the box, I finished sanding and touching up minor issues with the box so now im moving onto the chassis, took the front clip off, started marking wires and removing what good wiring is still attacthed to the firewall so that hopefully today i can have the cab off
now we know way you had your box off to power wash it.
Blue
This is gonna be a good-lookin truck ==kp ==wgm
AFurg85Chevy
Another update... Stripped down to the frame.. started needle scaling.. goin to take a wire wheel to it.. sand blast the frame if needed .. then start re-running brake lines.. suspension
ice87
Looking like a great start. Keep up the good work
woody11769
This is gonna be a nice truck, youre doin it right ;D
GOT ALOT DONE SINCE THE LAST TIME I WAS OVER!!! THIS THINGS GONNA BE BAD ASS ONCE ITS DONE!!!
AFurg85Chevy
So ive been busy but slacking all at the same time, but heres an update with some missing pictures, Goin to Silver Lake on the 4th and i need to get this truck done.
AFurg85Chevy
Gettin there
the 4th is sneaking up real quick!!!
AFurg85Chevy
Update.......Almost done.. Took it to silver lake this past weekend.. now i have more to fix...
