New Bogger Project "Sh!t Happens"
Started by OHEARN.2012, April 19, 2011, 03:34:58 AM
so went out and i worked on it today got most of the interior torn out hoping to get boddy of it tear front clip off and cab send it in for scrap bring frame in barn and clean and paint it. build some sturdy tow points building a 4 inch body lift for it lots of work to do in the next couple weeks
rangerwheelinmike
rangerwheelinmike
i told u black with white stripe and call it the skunk lol
lol i like the green with black strips then bogger tread goin down side
rangerwheelinmike
rangerwheelinmike
whos guna paint the bogger treds ?
rangerwheelinmike
just find a bogger and dip it in paint and roll it down the side ==roll
haha might have to do that.
i figured id do it along back behind wheel well
I need the motor if you decide to get rid of it ;D
come take a look at it if ur interested in i id sell it i wanna go carb
go with a 6 inch lift with the body lift! cant go wrong with bigger tires!!  ==djdj
rangerwheelinmike
ill share my treated 4x4s if you wana do a body lift ==roll
i might be picking up a lift here soon idkif its a 4inch or 6 inch its off my cuzins old blazer it has a 4 inch block but im not sure if it has add a leafs or not.  haha yea i could just build a house on top of the frame
ok so ive done some hard thinking  ==doh and well i think instead of using the stock door panels imma try and make some diamond plate door panels. theyd be alot stronger and easier to clean. but has anyone ever made any of these??
also im thinking about getting a radiator and running it in the bed with 2 electric fans and then taking diamond plate and using it to cover the hole in front clip so it keeps engine compartment a little cleaner  ;D also going to be building some bumpers out of 5 inch square tubing or round pipe
rangerwheelinmike
if you do tube bumbers make sure its small enuff that you can just slide a strap over it
if you are going to use pipe for bumpers and do like mike said it has to be 4" tube and smaller for that.
