New Bogger Project "Sh!t Happens"
Started by OHEARN.2012, April 19, 2011, 03:34:58 AM
ok here are some pics of the carnage
more pics of truck after mud boggin
ok so i think i found a name for my bogger. i got this name because when i broke it i was all  ==censor ==pissed about it and didnt want anything to do with it. but my buddy zach said hey man its a bogger no matter how much money ya put in it or how ya build it p00 breaks that cheered me up a bit and he helped me get it going again. so today i came up with a new name "p00 Happens" ;D
i got some more pics of the carnage but having trouble getting them on my comp.
but i popped diff cover off this afternoon and found about 2 inches or so of mud setting on the bottom of my diff and a mi of water and gear lube.
also found pieces of the inner bearing cage and a whole bunch of bearings so right now this axle isnt looking good
sounds like you got urself a new paperweight loll
bigmud44
#106
dont feel bad twisted too destroyed rear end 2 weeks in row ==censor if the back axle had that much mud in it  I would check front axle & tc last place we ran it was pretty nasty got pulled out of deep p00 3-4 times
355REDNECK
Quote from: bigmud44 on May 30, 2011, 06:39:38 PM
what kind or rear end its twisted running
WHEN IN DOUBT THROTTLE OUT
here are some more pics
and some more
yea i plan on pulling it into barn and dropping trans and tcase looking over both of them and seeing if we can get the tcase into 4 low lock.
my 14 bolt ff is going in and going to tear appart whole front axle
rangerwheelinmike
becuz if the back is this bad itd be a good idea to look at it. and tighten up the one wheel bearing....
had some ideas flying round my head instead of throwing in the side latch windows i thought bout getting some diamond plate and cutting it to fit where the windoes were and painting it black and maybe put some graffix on them and using them instead of the glass ones idk when its going to be back up and running due to not having alot of $$$
id do the diamond plate idea, and you could make some U shaped cuts and bend them out slightly like louvers
Quote from: Kyle on June 03, 2011, 06:06:40 AM
how the hell coould i do that?
rangerwheelinmike
Quote from: OHEARN.2012 on June 03, 2011, 06:19:10 AM
cutoff wheel/grinder. just plunge cuts and straight lines. thats how id do it at least. itd have cleaner edges than a plasma cutter
Proud and Powerful
Quote from: Kyle on June 03, 2011, 06:04:35 PM
so ur saying cut it out then do plunge cuts with die grinder then push them out??
