New Bogger Project "Sh!t Happens"
Started by OHEARN.2012, April 19, 2011, 03:34:58 AM
well i took her for that ride around yard so far no problems need to tinker with brakes a lil more and it will be ready to bog this weekend
well took it out to ellis rd today ran awsome made it threw some p00 but got stuck in some of the stickier stuff.  need to get my self a new battery one in it is not so good. have to also run some thicker battery cables for grounds. have a guy that offered to help me this winter on some of the stuff i want to do. he was smart as hell he knew wat he was talking bout helped me get my truck back in the mud. had a timing issue he said its off 3 or 4 teeth so im not getting alot of power but im going to take trans tcase and engine out and completely wash everything have to replace trans filter and replace fluid plus check t case and front axle might make it to millington comp but idk yet
rangerwheelinmike
it went better when i was driveing lol i herd the valves float once when i was driveing loll you need a tack bac
Rumor Has it!
Kyle dont put it in Millington or do u have aq diff set of tires cause ur running in bog 6 with Henry and Hillbilly Stomp
Bowtie Or Die..
lol i prolly wont be thinking shes done for the year i want to get everything i want done to it now. need to move radiator to the back and box in motor better
well i washed it and found some breaks. first off pass side tire sits crooked i think i blew up the bearing in it. second i hit a hole hard and smashed lower plate up into the fan and that in turn caught my lower rad hose. i cant keep blowing all my money on this so im callin it quits for this year and its time to wheel her in the garage and do some upgrades. cameras broke so i cant take pics like i wana but i fit some 40 inch hawgs on the back may need to trim a lil but nohting major i dont think
Prolly the smartest thing to do with all ya have broke and issues with it
rangerwheelinmike
so when u went in that one hole all that steem was from the hose?
yupp didnt think to get out and look when i saw a path of water from hole to trailer...
i was thinking stock 454 i know places to get them for 500-600 keeping it stock then boring better heads etc later just so i have a base motor for next year but i think it would go pretty good with the gears and tires
god i cant get rockwells off my mind since trucks gone wild make me wanna save up and go get a pair from dave woods
355REDNECK
WHEN IN DOUBT THROTTLE OUT
if u go big block i have a .550 lift cam lifters valve springs and timing chain and gear ill sell u
right now im not sure wether to go big block or smallblock becuz if i want to do rockwells then i want high r's
you can turn high rpms with both big or small block it all depends on how u build the engine and gearing
well with rocks its 672 gearing but wat the best big block for high rs?
hmm found myself a 454 runs its outta a 77 burban going to see how it runs this monday
Quote from: OHEARN.2012 on August 01, 2011, 04:55:22 PM
one you spend a ton of money on! lol a 396 or 427 should rip some rpms!!!
