What sbc head does everyone use?? Seceret Unlocked!
Started by ourlittleranger92, December 14, 2011, 02:23:36 PM
ourlittleranger92
Now I know the way to go is Brodix when coming to hi-horse power. But I was just wondering if anyone knew about the Vortec Flow numbers and how Good those things actually are. Now im Building a set for my 84 monte and they are going on a 383 stroker. They are the 062's so the little bit better than the other ones. I had them bench flowed and the numbers came out:
@500 lift- intake 240cfm
@500 lift- exhaust 160 cfm
Now that I have port work done and about as far as those things can open up we have found these numbers:
@400 lift- intake 320 cfm
@400 lift-exhaust 224 cfm
We didnt have much time cause we had alot to do but when we seen those numbers we were stunned. Needless to say I sold my edeljunk heads and went back to a GM head. we have 3 cars going in the 10sec area ON A GM HEAD! AND ON MOTOR!
Anybody else find hidden secerets in a big 3 manufactured head?
Chevy Race Car Ford Mud Truck
Chevy Daily Driver
chevystudz7105
i know everyone is not going to agree on which is the best head to run on a sb  but i was always told if you can afford it  the best to go with  for a sb is a set of afr heads.   if i was to build another small block id be runnin a set of them on it.
ROCK
just picked up a set of 906's for a new project. they'll be going on a 383.
I like my dart iron eagles but if I had the cash I would have some afr heads!!!!
iron eagles are nice heads, probly the most widly used in dirt track racing
I didn't realize that vortec heads flow numbers were a secret loll
#6
I'm not calling you a liar but I have a set of 227cc afrs with a 210 intake valve and per your numbers they out flow mine. I'm very skeptical of those flow numbers.
ourlittleranger92
I Have the Sheet and there are numbers on the internet. and that 210 they say on a AFR is a lie! Those AFR's are bada$$ heads. Those things work, so Yes for aftermarket head I would go with a AFR or Brodix. But those Vortec head's are Very underestimated. We have a buddie hitting hi 9's with a little over .500 lift cam on a stock bottom end 350 and a 1.94 intake valve still! in a 1970 nova. with a 150 little juice shot of course
Chevy Daily Driver
i've seen some impressive numbers out of vortecs, and i've said a million times, bigger runners don't mean more power.. you can actually loose power with to big of a head on your motor, the vortec's  "secret" is how they build velocity into the air charge, and how they get their flow outa smaller runners
Quote from: Jjay78 on December 15, 2011, 04:29:53 AM
none of that matters when you are talking about the volume of flow
#11
It may matter if your talking from a horsepower standpoint.  A opening the size of a dime well not produce the flow that a quarter size will. Velocity is a measure of speed not volume.
ice87
What porting did you do to these heads to get those numbers?
ourlittleranger92
We did alot of porting on these heads. About as much metal you could get out of them double barrel rolled. smooth as glass ports. short sides were cleaned up and the edge gone. the exhaust port is alot bigger than it used to be. the guides have been taken out. and bowls cleaned and cut. we left the Stock 1.94 int and 1.50 exh valves in them because we did not need any bigger. its on a .500 lift ish cam with a 108Lobe Sep. custom Grind low duration. 13:1 comp. These heads are no joke. My edelbrock performer RPM's Fully ported do not compare to these things.
Chevy Daily Driver
ourlittleranger92
Sorry if theres a Confusion, They are not the Stock valves they are stainless but stock sizes. On a 5-angle Valve job
Chevy Daily Driver
scary10
355REDNECK
are the throttle body heads considerd vortec heads
WHEN IN DOUBT THROTTLE OUT
ourlittleranger92
Quote from: 355REDNECK on January 21, 2012, 02:14:24 AM
No those are considers "swirl Port" heads. The vortec is 96-99. Those TBI heads are junk yet you can still get some numbers out of those.
Chevy Daily Driver
I've got a 4.3 L vortec in my s10 blazer and man let me tell you it is sick!!   Just kidding!!!
But I have been thinking of picking up a set of vortec heads for my 355, I think for the price and do a port and polish they are a good deal,  it makes me wanna get a set after seeing the flow numbers you got !!
