"THE HANGOVER"
Started by solid 12, December 29, 2011, 07:58:35 PM
solid 12
mudderboy
Have u tried to flex the rear with anything?
solid 12
Quote from: mudderboy on March 20, 2012, 03:01:36 AM
looking good bud!!!
Thanks Jermey!
Quote from: Blazin40s on March 20, 2012, 03:37:05 AM
I did..when i pulled out the engine i had one side of the front axle on the floor and the other had a bogger it..it flexed really well!
solid 12
I wish that i could take a voluntary lay off for a couple of weeks so i could finish it up lol
solid 12
I got a 3 day weekend, so hopefully i will make some good progress!
Blue
solid 12
I finally got the motor in today and got the motor plate mounts tacked into place
solid 12
i may have to get some headers made??  the motor is set back a few inches now and not sure if my fenderwell headers are goin to work..i have to pull the brake booster, abs mod, and ecm then i might have an idea if they will fit..i got some uprights but really dont want to run them unless i have to
solid 12
I got the coil spacers made and installed the rear shocks and limit straps..tomorrow i will bring it home so i can work on it during the week
solid 12
made a little progress today with the hour that i had to work on it lol..pulled the abs, ecm, and throttle cable & cruise control off to make room for the headers..next is the brake booster and wire trimming
solid 12
updated pics
solid 12
leveled out the box and the rear suspension with coil spacers
solid 12
I wish it was going!!  Maybe the next one it will be done?  Theres not alot to do, just a ton of little stuff
Red97
the shocks look a little close to your truss. the axle is going to move rearword when the suspention compresses.
Quote from: Red97 on May 03, 2012, 09:14:30 PM
it wont move that much not enough to make a difference
solid 12
If it dont work, then i will redo it.  Its my first time messing with a custom suspension and im tryn to learn as i go.  May not be the best way but it's what i got lol..once we get our plasma cutter back working, i am going to clean up some of the excessive cuts with the torches my dad did..no complaints lol saved me some time
