"THE HANGOVER"
Started by solid 12, December 29, 2011, 07:58:35 PM
solid 12
solid 12
Its 95% wired as of today.  Dumped alittle fuel down the carb and it fired right up!  Still waiting for 2 an fittings to show up then the fuel system will be done.  Should be moving on its own power this weekend
solid 12
Fuel system is complete now!  Picking up some parts tomorrow so hopefully I will drive it out of the barn this weekend
solid 12
Finished wiring it up today after work.   Should have it all wrapped up tomorrow besides some finish welding
solid 12
Well my dad is going to let me use his if he's not using them.  Other than that idk yet?  I'm going to start saving up for some 40" boggers, hawgs, claws or some 16.5-16.1's
solid 12
Well I have a minor set back..I got the wrong tcase clocking ring.   Should have the new one wed/thur..found one gas leak.  Hoping that is it!
pit
That cross member looks good. Glad you can use it. Looks like it bolted right in.
solid 12
Thanks!   Might have to modify it to work with the clocking ring on tcase
solid 12
Well got the crossmember all done, made front d shaft today but because of clocking ring I need to either go up one position or grind away on the drive shaft so it doesn't bind..once that's good just need to weld a few things and change the fluids
solid 12
Ended up building a whole different shaft this morning..got it in and works great!  Got to do a nice holeshot today too
solid 12
Didnt get one lol..was a last minute decision lol..should have a vid of it soon
solid 12
Things are looking up for making it to tgw with it!
solid 12
Hoping to do some test and tuning this weekend!   I will get some vids this time
solid 12
So far I'm on track to leave Thursday night with the bogger!
solid 12
Had a great time at tgw with it!  But now I'm thinking of switching out to 2.5 ton axles and some very aggressive tractor tires in the 50" range..
What does everyone think???
