1979 Ford F-150 short bed build.
Started by dusty59, January 29, 2012, 11:47:48 PM
dusty59
Thanks!! I think I'm going to pick up a 750dp n try it. They are cheaper and easy to find to.
dusty59
38.5x16.5 on a 16 wide rim. For the rear. I have 38.5x14.5 and 14 wide wheels for the front.
dusty59
Dropping the ponys in. ==wgm
dusty59
My headers don't fit. They are for a 250/350. The engine perch is different. They ate headmens for a 460. They are clean. I want to sell them for $200 or trade for zoomies.
dusty59
The tires on the back n Fenders off. I think I'm going to run it like this for a while
dusty59
I just picked up some upright headers!!! The truck will be running this week.and if all goes well maybe a test bog this weekend.
dusty59
Another pic.
mudbillyredneck
Comeing alot good  applaudd
Did you use chassis saver or POR on the frame ??
If your in the market for a lighted lund visor ...I happen to have one foresale
What gears are you running ?
Do ya plan on grooveing the tarhs ??
dusty59
Im going to buy a tire knife this week n groove em up. I just used some off brand rust stop paint from ace. I'm not sure of the gears. I'm going to change over to 2.5 tons this winter so I haven't even looked into it.
dusty59
I got some poopy uprights for now. I'm going to try to get some mad dogs made soon.
blittle913
How much do you want for the poopy uprights? I got cash! ++peace
When in doubt, throttle out!
dusty59
I need to run them for now. But when I get my new ones made ill take 125 for them. Im not sure when Im going to have the new upright made.
Hi Boy
DEC headers of ohio around 200 bucks for uprights !
forddd forddgal ==rocks
dusty59
Are they good? Oval port headers? Mine are circle and that restricts the flow a lot.
dusty59
so i put the motor in and fired it last week. it ran great. we tuned it in pretty close. however the next day it wouldnt turn over. i backed off the timing and still it wouldnt turn over right. i checked and changed my power wires etc. still not turning over more than a turn or so. I cant even turn it with a wrench. so i puller all the plugs ant there was a lot of gas on them and the starter will roll the motor over but its hard as hell. Im thinking i spun a main.
557stroker
is the oil pump rod on the end(bottom) of the distributor
Did u prime the oil pump befor u ran the motor
dusty59
I think the rod is in right. The ditributor set down ok on it. And I cranked the motor a few times before starting it to prime it. I was told that would be good because the motor had been ran before the way it is.. but if it wasn't getting oil would I have fried the mains?
dusty59
im getting back into the build. im going to poll the motor out this week hopefully.
fordrunner
Just out a curiosity what tran you running it it a stick or auto
